chbooth1
Jul 11, 2022Aspirant
Diasble Daisy Chain Nighthawk MR80
Total newbie here. I cannot for the life of me figure out how to turn off the wireless daisy chain on my MR80 nighthawk setup. The orbi instructions do not work on the nighthawk, but on the netgear ...
Jul 11, 2022Guru - Experienced User
How many MS do you have deployed?
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
chbooth1
MR80 V1.1.6.14
(2) MS80 satellites v1.1.6.14
Netgear Nighthawk CM2000
2 Satellites
4,400 sf
My best guess is that they are over 30 ft apart, Router is on main floor, one satellite in master on upper floor and one satellite in basement. Any suggestions to change the settings to not allow the satellites to daisy chain?
