mrwezzle
Sep 15, 2025Aspirant
Does the MR70 need to be wired to the RAX?
I'm trying to do the same with an existing RAX43v2. Will this same process work? If so, does the MR70 need to be wired to the RAX?
- Sep 15, 2025
Yes has to be ethernet connected to the host router.
Disable the RAX radios and configure the MR for AP mode:
mrwezzle
Sep 23, 2025Aspirant
I'm only running wired devices to the AX anyhow, so the disabling still worked for me. But very good to know that I could enable those in the future again if need be. Thanks!
Sep 23, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
