BioBill13's avatar
BioBill13
Follower
Jul 30, 2025
EAX11 Placement
My WiFi Extender is in a separate room about 50 feet from my WiFi Router.  The signal is 4 bars.  My car which requires a WiFi connection is parked outdoors another 50 feet from a brick wall.  The extender is in an interior wall plub right inside the brick wall.  The signal at the car is 1 bar!  There is a wall plug on the porch which is semi-protected from the weather but not the temperature.  Can the extender be placed in the outside receptacle and function at high 95° and low 0° temperatures?
1 Reply
  • FURRYe38's avatar
    Would need to try a outdoor designed Extender and see. the Brick wall maybe problematic as this material will inhibit good signal travel.
    WAX###Y series APs would be something to review as they are rated for outdoors use.
    Might consider a power line adapter from the main building out to the car area if power is on same circuit and place a actual AP in this location.
    Could run just CAT6A STP Lan cable there as well and install an AP.
