italianbeef's avatar
Aug 26, 2020
Help disabling Armor
Can someone help me figure out how to disable Armor? It's been causing me numerous issues, especially with video conferencing software.
I go into the Nighhawk app -> Settings -> Security -> slide the enable netgear armor swith to OFF, but it always times out with an error saying the process took too long (60 seconds).
Help!
  • plemans's avatar
    Try uninstalling the app and reinstalling it?
    Do you have a different device to try?
    • Yes - I've tried installing the app on another device, same problem. Rebooted router, restarted app.
      • plemans's avatar
        If you really want it disabled, factory reset the router and reinstall it.
