italianbeef's avatar
Aug 01, 2020
How to conifgure smart light bulbs with Nighthawk MR60
I'm afraid of the answer I'm going to get...but can you configure smart light bulbs with the Nighthawk MR60? They almost all require 2.4ghz (at least to initially connect). This also requires the mobile device with the configuration app to also be on 2.4ghz, at least temporarily.
It doesn't look like you can disable the 5ghz wireless network on the MR60, or force a mobile device to use the 2.4ghz band. Which means, smart bulb users may be in trouble?
  • I'm having the same problem with a Wi-Fi camera. Setup is supposed to be done by connecting your smartphone to a 2.4GHz access point because 2.4GHz is the only band the camera supports, and completing setup with an app.
    I too cannot find any way to temporarily disable 5GHz so I can execute the installation.  This, I now recognize, is a major ommission by Netgear. I've never had a router or AP where this could not be done.
    I had someone suggest disabling "Smart Connect," however, I cannot find any such feature in the browser-based setup. It is mentioned in the MR60 datasheet but is not mentioned in the MR60 users manual.
    • schumaku's avatar
      schumaku
      No, much more it's a problem your camera maker or the OPs IoT garbage must resolve. Complain with them. All the LAN and Wi-Fi interfaces are connecting to the very same network, the very same broadcast domain, the very same IP subnet. There is _no_ reason for such a requirement!
      It's completely irrelevant if a device does only support 2.4 GHz, only 5 GHz, or is an Ethernet connected device.
      • italianbeef's avatar
        italianbeef
        Star
        Appreciate the sentiment, but many low-cost IoT devices use a low-cost wifi chip. That's what makes them low-cost.
        And note that this is only an issue for initial setup - once you have connected one of these low-cost IoT devices with their low-cost wifi chips to your mesh network, everything is fine. This is only an issue for the initial configuration.
        Googling around shows a few possible solutions, including:
        • Using an old phone or tablet that is 2.4GHZ only for the initlal configuration.
        • Walking far away until your mobile device switches to the 2.4GHZ network.
        • Turniing off your wifi and creating a wifi network with the same name on a mobile hotspot. Typically, mobile hotspots on phones are 2.4GHZ. Then use another device for the initial configuration. Turn off the mobile hotspot and re-enable your mesh wifi.
  • schumaku's avatar
    schumaku
    No, the smart bulb makers are in trouble. They have to fix their rubbish discovery App and process, they need to learn about basic networking!
    Complain with the supplier and the makers/manufacturer of this IoT blubs!
  • I ended up buying Phillips Hue as it had a hub, it would not work with LIFX, but the hub connected no problems, the light bulbs talk to the hub, everything worked. I have no patience for workarounds, it should just work
