acayci's avatar
acayci
Tutor
Jan 19, 2026
How to disable Dynamic DNS Service on MR60
Hello,
I am trying to disable Dynamic DNS Service in Advanced -> Dynamic DNS.  Whenever I uncheck the box and come back it is showing checked again.  I don't see a Save button.   Any help is much appreciated.
Mustafa
  • CrimpOn's avatar
    CrimpOn
    acayci wrote:
    and click Apply
    Yes, clicking Apply is required.  Just unchecking the box is not enough.  All of the router settings are this way.
  • FURRYe38's avatar
    What FW version is loaded on the MR?
    What browser are you using? Try MS Edge or Firefox to see if this does anything different...
  • I think I needed to toggle with Yes / No radio button under Do you have a NETGEAR DDNS  and delete the information under that and click Apply.  Just unchecking Use a Dynamic DNS Service is not working.
    Mustafa
