Krixtian's avatar
Krixtian
Initiate
Feb 08, 2024
I have a MR80 with 2 MS80s and I think I finally got to the bottom of this issue
I have a MR80 with 2 MS80s and I think I finally got to the bottom of this issue. This has happened to me multiple times before and I’d just fix it by changing the SSID and connect everything one by one, until the next power outage. This last power outage I didn’t want to do that so I tried EVERYTHING before having to reconnect everything and fortunately found out that the issue isn’t the router, UNFORTUNATELY the issue is with random devices WIFI chips that were affected by the outage are trying to connect to the same IP as other devices, causing some devices to not connect.
So you either power cycle all of them manually, or change SSID and connect them one by one remotely fixing the culprits along the way.
  • plemans's avatar
    Or once you have everything setup, you go into the router and setup reserved IP addresses for those specific devices causing the issues. that should prevent that issue
    • Krixtian's avatar
      Krixtian
      Initiate
      OMG, that’s a great idea, I never thought of that, thank you!! It took me 2 days to get all my devices connected again. With reserving IPs, I should be safe after a power outage.
      I’m suspecting the issue are my Google Nest Cameras because those were the only ones that wouldn’t connect to the new SSID through the app until I hold down their reset button and start fresh.
