ErikaJB's avatar
ErikaJB
Follower
Sep 10, 2024
I have a Nighthawk Mesh Wifi 6 router, MR60
which went down this morning. I have managed to connect to my laptop but it will not re-connect to my iPhone or my partner's iPhone and iPad.  We are completely stumped as to what to do next.  We are both in our late 70s but usually quite computer savvy.
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
