Freak2277's avatar
Freak2277
I have a nighthawk mesh wifi 6 router MR80, it stopped working
My router stopped working and my internet provider says it might have reset itself. How done set it back up.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    • Freak2277's avatar
      Freak2277
      Thank you. I ended up resetting and reinstalling the router. I stopped for no reason. But seems like it is fine now. I had to download an app.
