searay268
Oct 01, 2024Aspirant
Internal network loses connectivity if internet goes down
We have a Nighthawk Mesh WiFi 6 (MR60) system with one MR60 and two MS60 satellites running firmware version V1.1.7.134. We have numerous wireless devices in our home such as smart TV, Roku devic...
Oct 01, 2024Guru - Experienced User
Ya that shouldn't happen. Everything LAN side should will work if the WAN side doesn't get internet services.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
So this happens if you turn OFF the MS and just have the MR running and a couple of LAN devices connected to the back of the MR, emulate disconnecting the ISP modem from the MR and connections between the LAN devices stops?
Any feature services enabled like IPv6, Armor, or SPC on the MR?
- searay268Oct 02, 2024Aspirant
I'll have to try the test you're suggesting; however, I can say IPv6 and Armour are disabled. Not certain what SPC is.
As far as the test you suggest, it sounds like you are saying to turn off the satellites and connect devices via cables on the MR, don't use WiFi. Is that correct?
- FURRYe38Oct 02, 2024Guru - Experienced User
No, just wondering if you do turn OFF the MS and then connect ethernet to the MR. Then disconnect the MR from the ISP modem, do the ethernet connected devices still get an IP address and able to see each other. Reconnect the MR to the ISP modem after trying this quick test.
SPC is Smart Parental Controls. Maybe seen on the Nighthawk app.
- searay268Oct 16, 2024Aspirant
Sorry about the delay.
My ISP modem is an Arris NVG448B.
I tried numerous things.
I already have a computer attached to the MR via wire. I connected my main computer I use that is on wifi via wire also. I did turn off wifi on the main computer. I then unplugged both MS satellites. I started a ping on the main computer to a roku device that is connected to the MR via wifi.
I then booted up my laptop and it created a wifi connection to the MR. I started a ping session on the laptop to the main computer. I used remote desktop from the main computer to the laptop.
At that point, I removed the connection from the modem. Everything stayed connected. I reconnected the modem at this point.
Plugged the MS satellites back in and removed the wire connection from my main computer and it established a wifi connection to one of the MS. I then used remote desktop again to the laptop (still connected to the MR) and then disconnected the modem from the MR. Connection did drop once and then came back.
I reconnected the modem and then got my laptop to connect to the MS. At this point, it's basically what I normally have. I restarted remote desktop again and then disconnected the modem one more time.
The connection did drop and I ended up logging onto the laptop directly. I could see the ping was failing to the main computer. After a few seconds, the ping started to work again and I was able to re-establish the remote desktop connection. After this, the connection seemed to be holding.
The whole time I did this, the ping between the main computer and roku device did not drop other than when I switched from wired to wifi.
In the past when the internet did drop, I could not re-establish the remote desktop connection to the laptop. I'm not sure if it was me logging into the laptop directly that helped or perhaps simply letting the MS satellites reboot.
