searay268
Oct 01, 2024Aspirant
Internal network loses connectivity if internet goes down
We have a Nighthawk Mesh WiFi 6 (MR60) system with one MR60 and two MS60 satellites running firmware version V1.1.7.134. We have numerous wireless devices in our home such as smart TV, Roku devic...
searay268
Oct 02, 2024Aspirant
I'll have to try the test you're suggesting; however, I can say IPv6 and Armour are disabled. Not certain what SPC is.
As far as the test you suggest, it sounds like you are saying to turn off the satellites and connect devices via cables on the MR, don't use WiFi. Is that correct?
Oct 02, 2024Guru - Experienced User
No, just wondering if you do turn OFF the MS and then connect ethernet to the MR. Then disconnect the MR from the ISP modem, do the ethernet connected devices still get an IP address and able to see each other. Reconnect the MR to the ISP modem after trying this quick test.
SPC is Smart Parental Controls. Maybe seen on the Nighthawk app.
- searay268Oct 16, 2024Aspirant
Sorry about the delay.
My ISP modem is an Arris NVG448B.
I tried numerous things.
I already have a computer attached to the MR via wire. I connected my main computer I use that is on wifi via wire also. I did turn off wifi on the main computer. I then unplugged both MS satellites. I started a ping on the main computer to a roku device that is connected to the MR via wifi.
I then booted up my laptop and it created a wifi connection to the MR. I started a ping session on the laptop to the main computer. I used remote desktop from the main computer to the laptop.
At that point, I removed the connection from the modem. Everything stayed connected. I reconnected the modem at this point.
Plugged the MS satellites back in and removed the wire connection from my main computer and it established a wifi connection to one of the MS. I then used remote desktop again to the laptop (still connected to the MR) and then disconnected the modem from the MR. Connection did drop once and then came back.
I reconnected the modem and then got my laptop to connect to the MS. At this point, it's basically what I normally have. I restarted remote desktop again and then disconnected the modem one more time.
The connection did drop and I ended up logging onto the laptop directly. I could see the ping was failing to the main computer. After a few seconds, the ping started to work again and I was able to re-establish the remote desktop connection. After this, the connection seemed to be holding.
The whole time I did this, the ping between the main computer and roku device did not drop other than when I switched from wired to wifi.
In the past when the internet did drop, I could not re-establish the remote desktop connection to the laptop. I'm not sure if it was me logging into the laptop directly that helped or perhaps simply letting the MS satellites reboot.
- FURRYe38Oct 17, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...- searay268Oct 17, 2024Aspirant
Thank you for the information.
