markris85
Sep 02, 2022Follower
Is the MR60 backward compatible with the EX6120 and/or EX6100v2?
I upgraded my home wifi network to the MR60 and satellite MS60 Nighthawk Mesh wifi-6. It so far works great with much-improved data rates and coverage. I'm sitting here with two AC extenders, the EX6120 and EX6100v2. I wonder if these two are compatible with the MR60 and could potentially extend my network if I ever wanted or needed to use them. Is this possible and if so, how would I do this? Not through the Nighthawk app, I'm assuming. Any ideas and guidance are appreciated.
MW
I presume they should work in a pinch.
Best to keep wifi sources to a minimum as there can be too much wifi signal in the home that can cause problems:
Would use the NH app or a wifi laptop that can connect to the EX setup web page as well.
Review the online user manual and installation guides here:
1 Reply
