acayci
Dec 19, 2025Tutor
Lose Internet as soon as I connect OpenVPN
You all remember me configuring MR60 for VPN Service. I established the Public IP address and DNS. When I connect OpenVPN from my MacBook, I lose Internet in my MacBook. I look under Port Forward...
CrimpOn
Dec 19, 2025Guru - Experienced User
More information, please....
When a MacBook is connected to the local network, it cannot run OpenVPN because OpenVPN is designed to provide access FROM a device on the Internet TO the local network (and devices that are connected to the local network). Some implementations of OpenVPN have options:
Notice that my VPN is set to allow the VPN connection to be used for both the Home Network and the Internet
OpenVPN also requires that the Home Network be a different IP subnet than the local network that the remote computer (MacBook?) is connected to.
If they are both 192.168.1.x, for example, it is not clear which network is which.
