MarkHalley7
Mar 22, 2022Tutor
Mesh won’t load websites on iOS
We have a Mesh MR60 (router firmware v1.1.6.122) getting 600MBPS speeds to the house via cable (connected to a CM1100 modem). iPhones on iOS 15.3.1 will frequently not be able to load webpages when on...
Mar 22, 2022Guru - Experienced User
1. do you have IPv6 enabled?
2. is random mac/private IP enabled on the iOS devices? (try disabling it)
MarkHalley7
Mar 23, 2022Tutor
Thanks, plemans, for the reply. I tried turning-off the Private IP, but there was no difference in the iPhone behavior. And I'm not techy enough to know how to turn-off IPv6, but initial research online says that may not be a good option to take.
Any other thoughts? Thank you!
- plemansMar 23, 2022Guru - Experienced User
I meant to make sure ipv6 enabled. Its disabled by default.
Did you try going into the iphone and forgetting the network settings and reconnecting them?
- MarkHalley7Apr 01, 2022TutorHi plemans, I reset my network settings on the phone, but no luck. Certain webpages are still refusing to load. Some load quickly, some still slowly but the eventuality get there, others start to load but never finish. Even to open this community forum page I had to turn-off wifi…loading via cell service works great, just can’t get it on wifi.
- plemansApr 01, 2022Guru - Experienced User
did you try IPv6?
Or a different dns provider? You can try googles at 8.8.8.8 or 8.8.4.4?
