makauchan
Mar 15, 2022Follower
MK62 Question
Hey guys. Having some poor signal throughout the house with a single router setup. My question is since I already have a nighthawk router that I want to continue using, can I use the MK62 router as...
Mar 15, 2022Guru - Experienced User
The MK system needs its own router managing it.
So you need to use the MK as a router. But you can put it in access point mode.
So you can hardwire it in at a different location/area of the home with it in access point mode.
You won't be able to integrate it with your current router but the current one can act as a backup or even to offload the current network.
