makauchan
Mar 15, 2022Follower
MK62 Question
Hey guys. Having some poor signal throughout the house with a single router setup. My question is since I already have a nighthawk router that I want to continue using, can I use the MK62 router as...
EternalStudent
Mar 16, 2022Apprentice
Bridging wireless networks is often a bad idea. One of the supposed benefits of this mesh system was a separate channel for backhaul (like an extra virtual wire instead of using up the client bandwidth). You can't use that to talk to your existing router.
I've also had issues getting wireless bridging to work. If possible just install an ethernet between the existing router and the router part on the mk62 (mr60) and you'll be happier.
