dayhawking
Mar 31, 2025Aspirant
MK62 wifi and wired connection issues
I have MK62 connected to Verizon FIOs ONT. The satellite is connected wirelessly.
Recently, a computer connected through a switch to the MR60 could not get a connection, probably could not get an ip and/or dns information. Bypassing the switch, restarting the MR60, or restarting the FIOs ONT did not seem to help. I believe the computer was also rebooted. All the while, wifi connections to the cell phones seems to be working. The problem seems to clear on its own overnight.
Today, a cellphone connected via WIFI seems to lose network connection, seems on 5Ghz through the satellite, for a minute each time for several times, disrupting google voice calls.
The MR/MS firmware seems up to date since long time ago.
Any advices on tracking down the problem?
A known problem is that the MK62 does not support older (e.g. 2012 version) WIFI clients but netgear ex6150 can bridge them. Hope MK devices can get firmware updates supporting the older WIFI clients.
what modem/gateway do you ohave from verizon? They aren't known for just having ont's. they tend to have gateways that cause a double nat.
- dayhawkingAspirant
The armored fiber from outside went into a box, which seems connected via a smaller fiber to a NOKIA branded device, which provided IP and phone connections. My MR60 connects to its IP port directly and is then chained to a netgear switch GS105 for wired connections.
Not sure what model the NOKIA box is. It looks the same as a "Nokia 3FE52343APAA Optical Modem Verizon" selling on ebay right now at https://www.ebay.com/itm/186327504752
The label showed 4p92 besides the UL symbol, P/N 3FE52343APAA, ICS 01, and my device shows MRev 03, MFG: month 01, year 2021, G-211M-C, etc.
what actual firmware is on the router/satellites?
Are you using the extender with it?
