Vpatel803
Oct 30, 2020Follower
MK63 & Chromecast
Recently setup Nighthawk MK63 Wifi 6 Mesh system. Living Room chromecast setup perfectly and connects to the main router since that is also in the living room. Problem is our upstairs chromecast is...
Christian_R
Nov 04, 2020NETGEAR Employee Retired
Hi Vpatel803,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
