shixinhb
May 04, 2022Follower
MK63 DHCP not working
Hey, I have my mk63 connected to a Arris SB6141 modern with Xfinity. The DHCP is turned on on my mk60 main router. I have several devices that cannot automatically get a valid IP address from the rou...
May 05, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Smart Parental Controls enabled?
Try setting a IP address reservation on the MR for your devices:
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router?_ga=2.258726095.431341290.1651496399-938141478.1647526868
