IAndRoid's avatar
Jul 07, 2025
MK63/MR60 Mesh system drops internet when I change room
Hello Everyone,
Got this used MK63 Mesh Router system. After setting it up, I've encountered a problem. Where someone changes a room whole mesh goes down. No device gets internet for like 30 seconds. Then it gets back up.
I've updated the firmware.
Satellites are like 8-10 meters away from Router(Main Unit) and like 5meters away from each other.
I couldn't find anyone else having the same issue, maybe someone knows a solution/answer to it?
Thanks
  • I think,I figured out the problem. It's the modem. It somehow restarts the connection randomly. Ordered a RMA. Let's see if it fixes it
  • FURRYe38's avatar
    5 meters is too close in between the MS. Try 8-10 meters.
    What is the size of the home in sq feet?
    What devices are being connected to the system?
    What channels are you using on the MR? Try 1 and 40.
