notabot
Aug 25, 2021Aspirant
MK83 – satellite drops internet for all clients, but internet status = good
Vexing problem and would love help – here's the rundown:
- Brand new MK83 mesh system
- Clients on satellite get strong internet speed test results (when it works) – ~80 - 110 Mbps
- Clients on satellite suddenly lose all internet access simultaneously:
- Randomly, intermittently, ~1-8 mins outage, can happen multiple times an hour or once every few hours
- However, clients do maintain a strong wifi connection to the RS80 satellite
- Clients on satellite can still connect to RB80 router admin interface (via satellite wifi) where it shows internet status as 'Good'
Troubleshooting
- I have verified:
- The clients are not connected to (or trying to connect to) the router
- The clients do all lose internet at the exact same time
- The clients can connect to 192.168.1.1 (via the satellite wifi) and see internet status 'Good'
- Have not tried (but will try):
- Swapping a different satellite into my work area
- Confirming that the internet is actually working for a device connected directly to the router (during an outage)
Can anyone recommend any other steps or think of what might be happening here?
This is super frustrating and doesn't seem to happen with any rhyme or reason :smileyfrustrated:
Thanks in advance!!
- notabotAspirant
Just realized I got the model of the router/satellites wrong. They should be:
Router: MR80
Satellites: MS80
What is the distance between the router and 📡 satellite(s)? 30 feet is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- notabotAspirant
Thanks for the help FURRYe38.
I monitored the internet uptime using a simple chrome extension on both satellites and saw that the time of short outages seemed to be synced up. So then I monitored the wifi router and a sattelite and that also had outages happening at roughly the same time. To rule out a bad modem, I picked up a new CM1100 at Costco yesterday.
I have still seen small outages on the wifi network, based on the connection monitor log, but I haven't been able to monitor the modem to see if that is also getting the same dropped connections.
At the end of the day, it seems like the mesh network might not be the issue. However, it's still odd to have the wifi router report that the internet connection status is good when there is no working internet.
Thanks again for your help with troubleshooting.
Let give feedback to the questions presented so we can better get an idea of your configuration.
