Andy_Shiekh's avatar
Andy_Shiekh
MK83 firmware 1.1.8.20 problems
MK83 firmware 1.1.8.20 came out yesterday (Dec 1st 2025)
and I find the satellite keeps disconnecting.
Restoring to version 1.1.7.14 fixes the issue.
Anyone else seeing this?
    • FURRYe38's avatar
      Ok. Maybe needed somet settle in time.
  • If it helps, running the router on 1.1.7.14 and the satellites on 1.1.8.20 is problem free.
  • I have also had this problem earlier today, the satellite keeps disconnecting
  • The router first than the satellites (both manually).
    All units are separated by more than 30 feet and all was fine initially, but then I started noticing a satellite disconnecting periodically.
    Am back on 1.1.7.14 and see no problems and the units make no attempt to update automatically.
    • FURRYe38's avatar
      MS need to be updated FIRST, then the MR lastly.
      A factory reset should be performed as well after new FW has been loaded.
  • FURRYe38's avatar
    Did you update the MS first then MR lastly?
    How was the system updated? Manually or was it Automatic?
    Two MS deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between MR 📡 and MS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
