RayVil79
Nov 03, 2021Aspirant
MR^0 disconnecting
I have asked the tech support to install the product andhave issues of sattelite disconnect everynight. I have talked to them about help and have updated the firmware. It did not help at all. Tech su...
Nov 04, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- grajkovicDec 02, 2021Aspirant
For my configuration, I'm using two Netgear switches (that worked fine for this Ethernet backhaul prior to mid-year firmware for MR60/MS60), but they are:
Netgear GS108
Netgear GS116
What I *think* may be happening, I think that the EEE 802.3az "green ethernet" feature may be interfering with the most recent firmware builds of these devices - nothing else in my configuration changed - firmware upgrade for MR60/MS60 and "boom", Internet connection works for a bit, Ethernet backhaul to two APs, and then the link degrades rapidly.
Remove one satellite, and the link is OK.
Configuration goes:
Modem --> GS108
GS108 --> Satellite 1 (Currently Disconnected)
GS108 --> GS116--> Satellite 2 (Connected)
If I reconnect Satellite 1, things work ok for a few hours, and then BOOM, Internet connectivity becomes unrealiable - network connectivity "iffy".
Ethernet throughput is WORSE than Wireless throughput - this was not the case before.
So to resolve things in the interim, I've enabled Wi-Fi on all devices that I would otherwise Ethernet connect; not ideal.
Before I scrap the architecture and get new switches - I want confidence in a solution before I throw money at the problem.- FURRYe38Dec 02, 2021Guru - Experienced User
Netgear GS108
Netgear GS116
Configuration goes:
Modem --> GS108 <Where is the MR60 in all of this? I presume it's between the ISP modem an your GS108 switch?
Be sure all your cables are of good quality. CAT6 is recommended and it's not recommended to mixed older CAT# versions with newer versions. Keep with 1 CAT# version.
Also might try newer FW version for the 60 series:
Before I scrap the architecture and get new switches - I want confidence in a solution before I throw money at the problem.- grajkovicDec 02, 2021Aspirant
Oh... I just upgraded to that firmware and it destroyed my network. Now yet ANOTHER factory reset I just did... I hate this product so much.
Wi-Fi kept dropping.
