BloodHunter90
Jan 10, 2021Aspirant
MR60 - Android Connection Issue
Hi,
I have a Nighthawk Mesh WiFi 6 System, updated to latest firmware (V1.0.6.102_2.0.45).
I cannot connect my Android TV Box to the WiFi 6 System.
I can connect it to my phone using Hotspot, so the TV Box wifi antenna works.
What can I do? I have tried to hard reset the TV box but had no luck.
It is the only device I cannot connect, no matter what I use (password or WPS).
Thank you for your help.
- Christian_RNETGEAR Employee Retired
Hello BloodHunter90,
Have you had a moment to get in contact with the TV Box manufacturer? You may try performing a factory reset on your Nighthawk mesh system and run through the setup assistant again.
Christian
- BloodHunter90AspirantHi Christian,
I have reached the TV box manufacturer and tried to reset and update it, but still no luck.
I will hard reset the mesh system and see if I have luck with this solution.
Thank you.
Best regards
