Idk2022
Oct 27, 2022Follower
MR60 Compatibility
I have the MR60 Whole home system. That model appears to be outdated. What satellites will work with it now?
Its not outdated. Its just not the highest performing. You can use the MS60 satellites with it.
the newer triband you can use 2 versions.
- mnzs-blenAspirantIt’s easy mesh compatible router. Hence any extenders that has compatibility of Easy Mesh can be added !
https://kb.netgear.com/000061555/What-is-EasyMesh-and-how-does-it-work-with-my-NETGEAR-Mesh-WiFi-6-System
