Jmthorner
Sep 06, 2022Aspirant
MR60 continues to disconnect from Internet
I recently moved to a new house and switched from Xfinity to ATT Fiber. ATT router/modem is working fine and when I connect directly to that wifi I have no issues. My MR60, however, continues to lo...
Sep 06, 2022Guru - Experienced User
The att device is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Jmthorner
Thank you for this. How would I go in and make this change when I can not connect via the app?
- plemansSep 06, 2022Guru - Experienced User
Try logging into it via the browser. You can't change to ap mode (if that's your plan) from the app.
- DylanhavenSep 18, 2022Aspirant
plemans wrote:Try logging into it via the browser. You can't change to ap mode (if that's your plan) from the app. mywakehealth
Hi, I have a Netgear Nighthawk Mesh Wifi system set up. The new router (MR60) is connected to the old Modem/router via ethernet (I have turned off all wireless function of this old router/modem). I intend to run ethernet cables for other devices in my house, should I connect them up to the old modem/router combo that the MR60 gets internet from? or all into the MR60? Will it make a difference?
- plemansSep 19, 2022Guru - Experienced User
Dylanhaven I'd recommend starting your own post. Thread jumping isn't allowed.
Plus then we can get more details to help you better. (plus it prevents the OP's info from getting confused with yours)
