Jmthorner
Sep 06, 2022Aspirant
MR60 continues to disconnect from Internet
I recently moved to a new house and switched from Xfinity to ATT Fiber. ATT router/modem is working fine and when I connect directly to that wifi I have no issues. My MR60, however, continues to lo...
Jmthorner
Thank you for this. How would I go in and make this change when I can not connect via the app?
Sep 06, 2022Guru - Experienced User
Try logging into it via the browser. You can't change to ap mode (if that's your plan) from the app.
- DylanhavenSep 18, 2022Aspirant
plemans wrote:Try logging into it via the browser. You can't change to ap mode (if that's your plan) from the app. mywakehealth
Hi, I have a Netgear Nighthawk Mesh Wifi system set up. The new router (MR60) is connected to the old Modem/router via ethernet (I have turned off all wireless function of this old router/modem). I intend to run ethernet cables for other devices in my house, should I connect them up to the old modem/router combo that the MR60 gets internet from? or all into the MR60? Will it make a difference?
- plemansSep 19, 2022Guru - Experienced User
Dylanhaven I'd recommend starting your own post. Thread jumping isn't allowed.
Plus then we can get more details to help you better. (plus it prevents the OP's info from getting confused with yours)
