BV11's avatar
BV11
Follower
Jul 12, 2021
MR60 no cable detected
I bought a mesh system and have just tried to set it up. It's not recognizing it's connected to my Arris CM820 modem. I have tried all manner of restarting. Unfortunately, it took me a while to set it up (my office just finished it's remodel, I bought this in advance on sale), so my tech support options have expired even though I just took it out of the box. My modem connects perfectly with my old AC1200, but no matter what I try it doesn't recognize the MR60 router is attached. The MR60 has recognized the satellites. I need the extended wifi and I'm not tech savvy, so any guidance is appreciated.
1 Reply
  • plemans's avatar
    Try this.
    power off both the CM820 and the MK system.
    disconnect everything from both (even coax) and wait 2 minutes.
    then connect coax back to t he cm820 and power it on.
    Wait 2 minutes for it to fully boot.
    then connect the lan cable from cm820 to the wan port on the MR60.
    then power the mr60 on. Give it 2 minutes to fully boot.
    then attempt setup.
