blaspheme
May 15, 2025Aspirant
MR60 no longer syncs to satellites
MR60 router works fine, and the satellites had worked fine also. I switched the router to being an access point and moved it to another network. The router continues to work fine. The two satelli...
- May 15, 2025
Try following this to factory reset the MS and MR:
Bring the MS to same room as the MR, place around 10-15 feet away from the MR. You'll need to press the reset button on the MS and MR for 15 seconds then release. After the MR and MS reset, let the MS attempt to connect to the MRs default SSID name. Give about 5-10 minutes. MS should connect and turn BLUE, if the do, start the setup process with a web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
May 15, 2025Guru - Experienced User
