Runningtexas
Nov 26, 2025Aspirant
MR60 not seeing ethernet cable
I have had this MR60 mesh system for several years without any issue. However, it is now not seeing the internet via the ethernet connection. I can plug the ethernet cable directly into a laptop, a...
Nov 26, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Swap LAN cable for another.
Be sure to power OFF the ISP modem/ONT for 30 seconds then back ON, then power OFF then ON the MR unit.
- RunningtexasNov 26, 2025Aspirant
Firmware is V1.1.7.134. The modem is an antenna with POE supplied by the Internet provider. I don’t really know the details of it since it is mounted high on the house.
The cable is high quality and has been swapped already. As mentioned, I can hook this cable direct to a laptop without issue.
i have also done numerous power cycling variations as well.
