Runningtexas
Nov 26, 2025Aspirant
MR60 not seeing ethernet cable
I have had this MR60 mesh system for several years without any issue. However, it is now not seeing the internet via the ethernet connection. I can plug the ethernet cable directly into a laptop, a...
CrimpOn
Nov 26, 2025Guru - Experienced User
Even though a cable appears to be good, it is often a good idea to try another Ethernet cable "just in case."
Are you able to access the modem management and see if the modem detects what device is connected to it?
- RunningtexasNov 26, 2025Aspirant
I don’t really know how to access the modem management since it is an antenna/radio that connects to Visionary (the ISP)
