Runningtexas
Nov 26, 2025Aspirant
MR60 not seeing ethernet cable
I have had this MR60 mesh system for several years without any issue. However, it is now not seeing the internet via the ethernet connection. I can plug the ethernet cable directly into a laptop, a...
Nov 26, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Swap LAN cable for another.
Be sure to power OFF the ISP modem/ONT for 30 seconds then back ON, then power OFF then ON the MR unit.
Runningtexas
Firmware is V1.1.7.134. The modem is an antenna with POE supplied by the Internet provider. I don’t really know the details of it since it is mounted high on the house.
The cable is high quality and has been swapped already. As mentioned, I can hook this cable direct to a laptop without issue.
i have also done numerous power cycling variations as well.
