Runningtexas
Nov 26, 2025Aspirant
MR60 not seeing ethernet cable
I have had this MR60 mesh system for several years without any issue. However, it is now not seeing the internet via the ethernet connection. I can plug the ethernet cable directly into a laptop, a...
CrimpOn
Nov 26, 2025Guru - Experienced User
Even though a cable appears to be good, it is often a good idea to try another Ethernet cable "just in case."
Are you able to access the modem management and see if the modem detects what device is connected to it?
Runningtexas
I don’t really know how to access the modem management since it is an antenna/radio that connects to Visionary (the ISP)
