MFL100's avatar
MFL100
MR60 Satellite Orange Light Strange
Often, when one of my satellites shows an orange light, if I wave my hand near it, the light turns blue.  What is happening?
1 Reply
  • plemans's avatar
    I don't show an orange for the satellites but it does have amber, blue, white.
    If its amber, it doesn't have a connection to the router.
    Maybe something is causing interference between the router/satellite and you  moving between the 2 causes it to change? (maybe switches to a different channel)
