kane808's avatar
kane808
Follower
Jun 06, 2023
MR60 Slow WIFI
OK, I have been having some speed trouble with my Surface Pro 7 that I do 99% of all my work on. I ran a quick google speed test and discovered I'm only getting 80mbps up and down.
The Setup.
I have a Netgear MR60 router connected to a Frontier modem with ONT for fiber 1G internet connection. The Nighthawk app indicates the WAN speed is 940mbps down and 630mbps up.
I have 2 MS60 satellites wired thought a Netgear gigabit switch and have the router on the north end of the house and a satellite on the south end and another upstairs in the center of the house.
I initially thought I had WIFI congestion as there are some 70 devices connected over 2.4G and 5.8G networks. So I pulled out an old R7000 router and set it up as an access point and moved any device that was part of my home automation that didn't require a lot of bandwidth to the R7000 AP. I also used WIFI analyzer to check WIFI channels in the area and while the is some I changed the channels of both the 2.4G and the 5.8G networks on both the MR60 and the R7000 to clear channels.
The crux of the issue.
When I connect my Surface Pro 7 to the MR60 wifi and run a google speed test, I get the same speed as I did before, about 80mbps up and down. But when I connect to my R7000 (that I'm using as an AP and now has about 40 devices connected to it) I get near 600mbps up and down.
Same results with different devices on the WIFI.
What gives?
Upvote
1 Reply
  • FURRYe38's avatar
    What speeds do you see with both wired and wireless devices connected to the MR with the MS turned OFF?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the brand and model# of the LAN switch between the MR and MS?
    Be sure your using a good quality LAN cable between the MR, Switch and MS. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
