Gubear
Dec 17, 2021Tutor
MR60 wifi Mesh - It always requests to reset router password
Hello I have the Netgear MR60 Wifi Mesh, and lately every time I try to connect to the router to edit some options, it open the Reset Router Password page, and I can't avoid it. I have to change th...
Dec 26, 2021Guru - Experienced User
Ya a reset and walk thru the setup wizard should help solve this...
Gubear
Jan 07, 2022Tutor
Hello
I have reseted it and did the walkthrough all again and I'm having the same error.
Once that I have configured it, if I try to get into the router again, it will ask me to reset the password everytime.
- FURRYe38Jan 08, 2022Guru - Experienced User
Can you try this, reset the router and walk thru the setup wizard and if you can get to the home screen on the routers web page, go in and re-load the FW file to the MR using a wired PC and web browser firefox. If you can send the FW file, the MR should reboot. When it comes back to ready, don't try to access the web page, do a one more factory reset and setup from scratch and walk thru the setup wizard.
Use the FW file from this link:
Then see if you can access the MRs web page normally.
