kickns
Jan 06, 2022Aspirant
MR60 wireless devices connected to router can't ping each other or see shared directories
MR60 router firmware version V1.0.6.116 Two MS60 satellites firmware version V1.0.6.116 Here is the issue. All of my devices have Internet access and performance seems to be fine. However, two...
- Jan 06, 2022
turning off Armor and then turning off the MR60 and MS60s worked. I am going to turn Armor back on and live with the issue for now. Thanks.
kickns
I will try disabling ARMOR and turning off the MR and MS at an opportune moment.
Right now my workaround is to hook the two systems up via Ethernet. Given the low need for sharing between the two systems, that is probably good enough at this point. Will consider the updated firmware approach. Thanks.
kickns
- FURRYe38Jan 06, 2022Guru - Experienced User
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
