jjgonzalezh
Nov 23, 2020Initiate
MR60 with blue light while MS60 with amber light
Good afternoon. After a recent power outage the mesh came back on but I noticed the router has a steady blue light while the satelites have a steady amber light. On the Netgear app Network Map, the router shows a green dot while the satelites show a magenta dot. On the app the satelites wont show an IP adress or firmware version. When I wifi connect or cable connect my laptop the connection shows as unrecognized. What's the problem here?
Hello jjgonzalezh,
May you factory reset your Nighthawk Mesh system by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Nighthawk app.
Regards,Christian
- Christian_RNETGEAR Employee Retired
Hello jjgonzalezh,
Regards,Christian
- jjgonzalezhInitiateIt worked! Many thanks!!
