Nick57's avatar
Nick57
MR60/MS60 extremely slow WiFi speeds
Nighthawk WiFi 6 Mesh system is produces maxiumum speeds of 30mbs on a gigabit line. Even 30mbps only occurs in direct line of sight from the main router with a max speed of 15mbs off of one satelite. Just yesterday I was getting near 700 in direct line of sight and 250 off of the same satelite. I have tried multiple factory resets and firmware downgrades and upgrades. Has anyone else had this problem?
  • Edit: Direct router Speedtest shows 600mbs and wired connection directly to main router shows similar speeds. Issue is only with wireless
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hi Nick57,
      If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
      https://www.netgear.com/support/contact.aspx
      Christian
