trnd7
Apr 30, 2023Aspirant
MR70 router no longer able to access the Internet
Yesterday my MR70 Mesh router started displaying the amber light. I've been trying to troubleshoot this for hours but nothing is working so I'm wondering if anyone has any idea on what to try. He...
trnd7
Thank you for the quick reply! I read conflicting information about the CAX30 regarding modem or bridge mode, but I found a "router mode" in the admin settings and it seems to be doing the same thing. Unfortunately that didn't make the MR70 router be able to connect. So I'm looking into option #2 now.
EDIT: how come that this problem just happened yesterday after this network configuration worked for months? Is it possible that it was caused by an ISP change, since they told me that they are doing some work on their network at some point?
michaelkenward
Apr 30, 2023Guru - Experienced User
When you set up your network, the MR70 router checks what it finds and adapts its setting accordingly. It looks to see if anything else is squatting on its preferred local IP address (192.x.x.x). If it finds something, it picks a different address, usually 10.x.x.x.
Then the two routers will not fight one another.
If your network recently went through a reboot, maybe after a firmware update, maybe something forgot about those IP settings.
That's why you got the advice to put the CAX into "bridge" (modem only) mode
For some reason, unlike most modem/routers, the manual for your modem/router does not have instructions on how to put it into bridge mode. Maybe it doesn't have that option.
From other manuals, you could look here:
- Advanced
- Administration
- Router mode
You may be lucky.
By the way, in your first message you said that you reinstalled "via the app". This is to the most controllable way of setting up your network. This is best done with a wired LAN connection.
Did the list of things you tried include resetting both devices, modem and router, and then reconfiguring the network?
It might help to do this in the recommended order:
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- trnd7Apr 30, 2023AspirantThanks for your reply! I found a "Router mode" option for the CAX30 modem where I said no and it looks like it's in a modem mode (wifi disabled, wired connections no longer work, the admin site routerlogin.net no longer has the router options).
I also tried to setup DMZ on the MR70 router, but it didn't work, and then tried AP, but same result.
I make sure everytime I restart that I first switch off modem, then router, then switch on modem and after that router. I'm tempted at this point to reset the CAX30 modem to factory settings, then reset the MR70 router to see if a fresh install helps. - trnd7Apr 30, 2023AspirantI just noticed that my desktop computer is able to access the internet when WIRED to the MR70 router. Does this help understand why the wifi is not working?
- michaelkenwardApr 30, 2023Guru - Experienced User
trnd7 wrote:
I just noticed that my desktop computer is able to access the internet when WIRED to the MR70 router. Does this help understand why the wifi is not working?Could be. I fear that "just noticed" is a bit worrying.
We'd need more detail to pin down the problem.
All it tells me is that there's some missing information on what is happening at your end.
- trnd7Apr 30, 2023AspirantThe "just noticed" came because I had to move a lot of cables around since yesterday and never paid attention to that specific bit.
Right now, I set the CAX30 back to do modem and router at the same time. It works but I lack the mesh connectivity from the MR70 (and 2 satellites), that I disconnected until maybe someone make other suggestions.
I tried to provide as much information as I could above, but I only know so much about networking technologies and I appreciate everyone's help here.
