Kirby0625
Jan 23, 2022Guide
MR80 Router constantly reboots
My Netgear MR80 router is constantly and randomly rebooting. I currently have it setup in a Wireless AP mode behind my AT&T Internet router. I have disabled the wireless settings on the AT&T router...
Jan 23, 2022Guru - Experienced User
Have you tried a simple factory reset/reinstall (not from a backup)?
sometimes old settings can cause issues.
Does it do the reboot cycle in router mode?
Kirby0625
Jan 23, 2022Guide
I probably should have said so, but I have done a factory reset - several times. I'll try it again with the new firmware updated and see if that helps. I'm hesitant to put it in router mode because I don't want it to mess up my current LAN. I have a lot of devices using the 192.168.1.0/24 network and I don't want to create a new network using the default 10.0.0.0/24 with it in router mode. My ISP router is fiber so I have to use it or I would let the MR80 be the default router.
