Kirby0625
Jan 23, 2022Guide
MR80 Router constantly reboots
My Netgear MR80 router is constantly and randomly rebooting. I currently have it setup in a Wireless AP mode behind my AT&T Internet router. I have disabled the wireless settings on the AT&T router...
Feb 24, 2022Guru - Experienced User
there was another firmware released if you want to try.
otherwise, to get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
Kirby0625
Feb 26, 2022Guide
I've updated the firmware and I have it back in router mode with IP Passthrough enabled. How do I share the LAN IP (192.168.1.0/ 24) with the AT&T router? When I try to change it on the Netgear it says it's in conflict. Is there a way for both of these to be on the same network? Thiis was the orginal reason why I needed it in AP Mode.
