PearlJamFan
Apr 17, 2022Follower
Ms60 and Ethernet via switch?
Trying to setup a MS60 satellite in my backyard that has an Ethernet port. But when I check the details section in the Nighthawk app it always says the connection is 5ghz wireless. How can I verify I'...
Apr 18, 2022Guru - Experienced User
You mean you're trying to connect the satellite using a hardwired backhaul?
You can do that via a switch. I've seen some smart switches/managed switches that had issues but you can do that.
