meepadoo
Jan 15, 2023Aspirant
MS60 Offline with Blinking White Light
I have an MR60 router with two MS60 satellites. One of the satellites has gone offline and has a blinking white light. I have tried cycling the power. Additional troubleshooting steps are appreciated,...
meepadoo
Jan 16, 2023Aspirant
FURRYe38 the firmware currently installed on the MR is V1.1.7.132. I have never manually updated the firmware. Apologies if that was something I'm supposed to do regularly. I thought it updated automatically.
I have connected the MS to the MR via ethernet per your suggestion. I pressed the sync button on the MR and the led changed from solid blue to a faster blinking white. I then pressed the sync button on the MS (also tried holding it down for 5 seconds) but the MS led never changed from a slower blinking white, even after the MR changed back to a solid blue light, and the MS in question still shows not connected in the Nighthawk app.
I'll appreciate any other suggestions you might have.
Jan 16, 2023Guru - Experienced User
Ya we see sometimes that the auto update doesn't update the MS properly or before the MR.
Do you see the MS in the MRs web page under connected devices and does it report have an IP address there? If so, you can log into the MS web page using the IP address to check it's FW version and if it's not updated, manually update the MS by sending the FW file to the MS directly thru its web page.
Also there is newer FW available as well:
Users reported seeing issues with v.132 so you might want to update to v.134 on the MS first, then MR lastly.
