meepadoo
Jan 15, 2023Aspirant
MS60 Offline with Blinking White Light
I have an MR60 router with two MS60 satellites. One of the satellites has gone offline and has a blinking white light. I have tried cycling the power. Additional troubleshooting steps are appreciated,...
meepadoo
Jan 16, 2023Aspirant
FURRYe38 the firmware currently installed on the MR is V1.1.7.132. I have never manually updated the firmware. Apologies if that was something I'm supposed to do regularly. I thought it updated automatically.
I have connected the MS to the MR via ethernet per your suggestion. I pressed the sync button on the MR and the led changed from solid blue to a faster blinking white. I then pressed the sync button on the MS (also tried holding it down for 5 seconds) but the MS led never changed from a slower blinking white, even after the MR changed back to a solid blue light, and the MS in question still shows not connected in the Nighthawk app.
I'll appreciate any other suggestions you might have.
michaelkenward
Jan 16, 2023Guru - Experienced User
It does, unless you have disabled that feature.
A new version came out two weeks ago.
MR60 / MS60 Firmware Version 1.1.7.134 | Answer | NETGEAR Support
Maybe it hasn't got to you yet. Or something interrupted it, hence the symptoms you see.
