steveof2620
Nov 12, 2021Star
MS60 Satellite - No connected device found
Hello, I am wondering if anyone can help me understand why none of my devices connect to the Mesh Satellites. I have two satellites connected to my MR60 Mesh system, both are found in the phone app ...
steveof2620
Nov 12, 2021Star
I have reset one of my satelites and unplugged the ethernet cable. Yet the router insists it up and running with a wired connection. I rename the satelite in the app... of course it doesn't save the name.
I can't say I am terribly impressed with this system. What I can say is this has been a very disapointing purchase.
Nov 13, 2021Guru - Experienced User
Devices roam between the satellites/router based on their own roaming protocol. Its not the router/satellite that moves them.
what you can do to ensure the best chances of roaming?
1. make sure the satellite/router are at least 30 ft apart
2. Check your home size. If the home isn't big enough, the devices will default to the router. In this case, you can try turning down the broadcast power a bit and see if that encourages roaming.
3. try turning the wifi on/off on the device you're using. If it defaulted to the router and the distance isn't that great, a reconnect might have it connecting to the satellites.
