lrsantos's avatar
Dec 24, 2022
MS70 Satellite Advanced Config Options
When I login to the MS70 Satellite and scroll down the screen, there is an "Advanced Home" section with a bunch of settings similar to the router.  Should I change any of these to optimize the system further, or is it getting an optimized configuration through the sync with the router?
The one thing I know I would like to change is the device name.  When I tried to change it though and hit the "Apply" button I get an error that says "The IP Address conflicts with the WAN IP subnet. Please enter a different IP address."  I didn't change anything but the Device Name in the "LAN Setup" section.
Any suggestions on configuration changes at the Satellite?
  • If its working fine, I wouldn't mess with it. I don't have the MK system but most mesh systems are designed to let the router manage the satellites for better speeds/efficiencies.
1 Reply
  • plemans's avatar
