Weihan
Dec 13, 2021Follower
My mesh satellites are not working MR80
App version 2.13.0.79
Firmware v1.1.6.6
MR80
The satellites are always with orange light on, I tried moving them close to main router, reconnecting or resetting, but still not working
1 Reply
Had the MS been connected before?
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡Has a factory reset and setup from scratch been performed since last FW update?
Possible you might have problems with the MS being out of sync in FW:
Might need to get them up dated to same version as MS.
There is newer FW available for the 80 series:
