MartinCZ
Sep 14, 2022Aspirant
NetGear MR60 - SSH connection from Internet
Hi,
I have Nighthawk® Mesh WiFi 6 System MK62. Router + satellite (connected via wire). Both running on latest firmware: MR60-V1.1.6.124_2.0.59.
I use SSH connection inside my LAN to connect to my Raspberry Pi and NAS storage. All is working fine. However I can't connect from outside my LAN - from Internet. SSH connection always time-out.
I double checked Port forwarding rules (IP addresses and ports to connect to LAN devices): O.K.
Tried to connect to router using Dynamic DNS address and external IP address - nothing helps.
It seems that SSH connection is blocked when it comes from WAN. Is there any help for me? I do really want to use SSH connection..
Thanks for any suggestions
- MartinCZAspirant
Adding info for my Internet connection:
I have FTTH connection to my home.
First device is: TP-LINK MC220L which is a media converter of SFP to RJ45. From this TP-LINK goes wire to my Mesh Netgear router.
Did you disable uPnP on the MR before or after setting up any Port Forwarding rules?
Is any SPC or Armor enabled on the MR as well?
