toshigama
Jan 06, 2023Follower
Netgear MR60 in Access Point Mode - use the same network switch for LAN and Internet?
If you're using the MR60 in Access Point Mode, the "internet" port should be plugged into the main house switch that has access to the main router. Let's say that the main house switch that is a 16...
Jan 06, 2023Guru - Experienced User
It should go from your device supplying internet to wan port on the router. So whatever is supplying the switch, instead of plugging it into the switch, plug it into the wan port on the MR60. Then use the lan port on the MR60 to plug into the switch. Then the switch can feed the satellites.
- FURRYe38Jan 06, 2023Guru - Experienced User
